Ricoh aficio 2020
  • rschmitt
    • Feb 2005
    • 34
    Ricoh aficio 2020
    I have this beast which show a jam on the display. "open right side,follow instructions" and directs you toward "B". I have pullled this thing apart and there are no jams, broken sensor flags, everything looks good but I can't clear the jam.
    I have gone into the SP's but I don't see any sensor tests. I try to run 5803, but it just defaults to the error display.
    Help, please.
    Robert
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • kyoceran
      • 100
      check reg roller area, smal pieces of paper can get stuck and are not apparent, you may need to drop down the rh door ( full box of paper or a chair ussually suffices to stop the door dropping down, the sensor actuator for the reg rollers only has to be slightly displaced to register a jam .You may also have to unscrew the entrance guide located on the reg roller, this will drop down and give access to the possible jam
      good luck
      • jonhiker
        • 661
        good luck
        good answer. also, removing the pcu will help looking in this area. another is to remove the fuser to see if a sensor flag was knocked out of place.
        • ponto700
          • 144
          i already have 2 problems like this... and i just rotate the reg roller with hand and piece of paper came out from there..
          • Jomama46
            • 2900
            inputs checks are 5803 like all the other Ricohs
            sigpic
            A+; Network +; PDI+
            • rschmitt
              • Feb 2005
              • 34
              I have gone into the SP's but I don't see any sensor tests. I try to run 5803, but it just defaults to the error display. Can you walk me through the last part. Maybe I'm doing something wrong. I get to the "check right door sensor" option, choose "execute" and it goes right to the "open right door and follow instructions to clear B jam".
              Help, please.
              Robert
              • iMind
                Vacuum Cleaning Expert
                • Mar 2008
                • 1116
                Help, please.
                Robert
                open and close front door, hehehe............ it maybe as easy as that
                • akewldewd
                  • Dec 2012
                  • 83
                  Re: Ricoh aficio 2020
                  I just ran into this same issue with the same model and did this and out came a small section of paper. problem fixed.
