I have a 2051 with the standard B477 adf installed. On occasion, when feeding an original it will stop and say "load 71/4 x 101/2". I have replaced feed belt, pickup roller, reverse roller, torque limiter, adf paper size sensors, adf original size sensors, adf main pcb, skew correction sensor adf registration sensor, and the one way bearing the original feed shaft shaft fits into. It is a very intermittant problem when using 8 1/2 x 11 and 81/2 x 14 originals. Sensors all test good. I am running out of ideas.
