I've got an MPC 2500 with about 130k black and 37k colour on the clock producing a coloured shadow usually magenta or yellow around the black print on about a third of the copy on the rear side. The rest of the copy is fine and the shadow is only beneath the print, almost like a 3D effect, if I copy the meter reading printout in colour the shadow is the same thickness as the black line. SP 2111 forced line position adjustment a,b and c all fail and after 3 attempts i'm getting an SC 285. I've just whipped the transfer belt, laser unit and pcus out of the machine and i'm off to try in another customer's machine, just wandering if anyone has had the problem before in case none of the above are at fault when I try them.
Cheers.
Cheers.
