Ricoh 3030
  • mikadonovan
    • May 2008
    • 2936
    Ricoh 3030
    Hey, all,
    Can someone tell me the particulars of TSB 019 for the B209? It has something to do with the hot roller. I'm having some fusing issues on one of these machines and the info in the TSB may help.
    NEVER ASSUME ANYTHING
  • JohnJay
    3030 TSB #19
    Self explainatory, Ricoh listed the wrong part # in the manual and they are giving you the correct part #. Check the gear on the hot roller to make sure it is installed correctly. The gear may be worn down if installed incorectly. This is a great machine overall.
    • mikadonovan
      • May 2008
      • 2936
      Just a part # change, thanks. It wasn't self explanatory to me as I didn't have the bulletin.
      • teebee1234
        • Jul 2008
        • 1670
        Correct part # is AE011103
        • Magyver
          • Oct 2010
          • 12
          What are the fusing issues?
