developer spills
  • salmandol
    • Mar 2009
    • 107
    developer spills
    Lately i have been experiencing dv spills on af - 1075s,2075s,mp 7500s. the average count is 1 million to 1 1/2 million. Is anyone else experiencing this? Is this normal? What you think is the cause? I somehow believe it is because of the use of Generic toners.
  • TonerMunkeh
    Professional Moron
    • 3865
    It's perfectly normal. The seals wear out on the dev unit and mag roller allowing dev to leak onto the feed stations. We've been instructed to replace the dev seals every other dev change (approx 1.2m).
    Hit it.
    • tcs04
      FORMER Techie
      • 1183
      I make a pair of "Shields" from mylar or card and stick them to the frame below the reg unit to stop dev leaking onto the paper feed drive gears and motors. this prevents a whole lot of trouble, as usually, by the time you find the dev leak, you are getting major paper jams and have to rebuild all feed stations. I've seen the seals fail BEFORE the 600K PM on a new machine! (MP6000 using Ricoh toners!)
      • bbapst
        • Dec 2008
        • 42
        Where is the dev spilling? out the back onto the feed drive gears or on the mylar in front of the drum
        • salmandol
          • Mar 2009
          • 107
          Sorry i did not state it but it's bad dv bushing that causes the the leak, mainly the ones on the mixing shaft and sometimes also the shaft gets damaged, so it would still leak even if you put new bushings. in this case i would have to change the entire dv unit cause i can't find a part no. for the shaft.
          • Magyver
            • Oct 2010
            • 12
            I experienced the big developer leak thru these bushings on a MP5500, trashed all three feed stations. Was able to harvest feed stations from a R1060 and had to replace Dev unit. Apparently you can run the developer to long without replacing it, 1.2 mil. Probably would be a good idea not to run developer more than twice recommended pm interval.
            • katash
              • May 2010
              • 221
              its requires for you to replace the dev.unit,the bushings are a temporal measure
              • bbapst
                • Dec 2008
                • 42
                I replace the rear bushings every other dev change. Since I started doing that I haven't had a problem. I have several machines with over 3 million on the dev units.
                • katash
                  • May 2010
                  • 221
                  bbapst,gud tip,will take it up!
                  • gnr115
                    • 11
                    Please, can you put the code number of parts to repair Developer Unit.
                    If the developer leak into feed unit, can i repair this unit or i need replace this paperfeed unit.
                    Thank you
                    Sorry my bad English
                    • Infidel
                      • 21
                      I have had 2 this year. (One this very afternoon) The 1st was a Lanier LD175 with 5 million- I can let that one slide. Today's developer leak was on a LD275 with 1.1 Million. (not too good) The bad thing is not so much gutting the machine to clean and replace the DV unit, but the developer eats the one way bearings in the paper feed units. Nasty deal!
                      • salmandol
                        • Mar 2009
                        • 107
                        when dv leaks onto feed units you need to check all the gears and one way clutches. if they are damaged they cause timing problems and jams. once i see one bad i change all as a set. i can't handle the call backs. when it leaks to the front then we are talking about motor problems. when i clean them they usually work fine. i have only had to change a few. in my opinion a dv leak is the worst thing that could happen in these machines.
