Ricoh 5560/Toshiba550C Exit assembly
  • tech07
    • Aug 2008
    • 410
    [Jamming] Ricoh 5560/Toshiba550C Exit assembly
    Ok guys, I have an exit assembly on one of these copiers that is such bad shape with warped paper guides, bad shaft rollers that I am trying order an entire exit assembly. The Toshiba book does not list it but I thought the Ricoh one or Savin one might. I hate the thought of taking half day to rebuild or ordering 15 parts..Have ok from boss to order if I can find..Could someone check their parts book and see if it is different than my toshia or if it's available as an assembly??
  • teebee1234
    • Jul 2008
    • 1670
    B1324430 Paper Exit Unit (includes Paper Exit 1, 2, & 3)
    *Found in Section 51 -Paper Exit 1 page 117, doesn't indicate it in the graphic blowout on pg 116 available as an entire assy but is (*) in the parts list on 117.
    I generally replace the entire assy too when I start having problems. Getting it in is a bit tricky, be patient. You'll have to finagle it in, don't force anything.
    • turbojetboy
      • Aug 2009
      • 279
      Or you can put in the 7500 version d0147001, or the 7501 d0817001. The d081 is supposed to be made of better plastics...........i just use the d0147001 in all models
      • tech07
        • Aug 2008
        • 410
        Although it's definitely not listed in the Toshiba version parts list, I plugged in the part number and it was accepted by Toshiba Pats... Thank you.. my exit unit is on the way
