What John said - I'll try tomorrow and see what happens. Thanks everyone!
gestetner dsm645 Service mode question
THANK YOU!
Thanks, teebee, my bad.
i found this on the TSRC global knowledge base for this model:
What to do if the administrator password is forgotten.
Answer Administrators do not need to enter a username. They only need to remember their password. If this password is forgotten, please try the following:
1) The admin password is the same for both WebImageMoniter and telnet. Ask whether the customer remembers either of the two.
2) Try the factory default "password".
3) If both 1) and 2) do not work, a service engineer has to reset the password for the customer. Follow these steps:
3-1) (IMPORTANT) Print a configuration sheet at the beginning. You will need the configuration sheet to restore the network settings.
3-2) Enter SP mode.
3-3) Enter SP 5-801-011 (Memory Clear > NCS).
3-4) Press [Execute].
3-5) You will be asked for confirmation. (IMPORTANT) This will reset all of the network and interface settings. Make sure you have printed the configuration sheet. Press [Execute] once again.
3-6) Turn off the device, then turn it back on.
3-7) Restore all the network settings to the values of the configuration sheet.
3-8) The above steps should have reset the password to the factory default, "password".
3-9) Finally, the customer should log in to the device and change the password to their own. This can be done using Web Image Monitor or telnet ("passwd" command).
Products US
Gestetner
Black & White Multifunction
DSm415/f/spf
DSm615, DSm618/D, DSm616/620/620d
DSm622, DSm627
DSm635, DSm645
pagin
Re: gestetner dsm645 Service mode question
3-2) Enter SP mode.
I faced the same problem with admin password reseting on Nashuatec NRG645 device. I was able to go into SP mode but do not know how to go with next step:
What it means? Any keys combination? Which keys?
BR,
WojtekComment
Create another thread my friend. you will receive more replies about yours.Nobody is perfect..Comment
If you are not trained in using the service mode you should stop now, and hire a trained professional. Changing settings in service mode without knowing what you are doing, especially memory clear, will damage your machine.Comment
