hi,i got 2027 machine,but don't know how to install scan to folder,pls to help,thx
2027 scan to folder
Tags: 202, 2027, folder, install, officially, sca, scan, scan to folder, stall, web image monitor, win xp
You will need Scan Router Lite. Do a search of the forums for all of the discussions on it and where to download the software. You will probably be better off setting up Scan to Email instead. -
teebee, are you sure about the scan router? The 2027 should be able to scan directly without the scanrouter, but you are in need of the printer/scanner option and the memory upgradeIf sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!Comment
you are correct. the 2027 is the first model to support SMB folder scanning. you can also do scan to email. there is also a custom firmware update needed if scanning or printing via a share on server 2003.Comment
I'd recommend replacing the Toshiba hard drive supplied by Ricoh before you go to the bother of setting up the address book.Comment
You're right herrmann, I must of been thinking of the 1027. Thanks for the clarification.Comment
E Winter
It might be self-explaining if you handle it via the web-interface. I think the default admin log-on is no username and "password" as password. Once logged in you should be able to access and manage the adress book.Comment
Are you talking about the hardware option or do you have problems software-wised? You can download all user manuals from ricoh's end user website in case you don't know how to register a scan-to-folder adress.
The Password is password
Newer machines have a logon user name of admin
Just hit enter or ok. A password isn't needed.Comment
Attached is the Scanner Reference Manual that will help you set it up.Attached FilesComment
"Jan Sommer:
It might be self-explaining if you handle it via the web-interface. I think the default admin log-on is no username and "password" as password."
You won't find any reference to the web image monitor in the Aficio 2022/2027 users manuals and you won't find it in the service manual either.Comment
smushrin01
l think the problem comes on the computer configuration, win xp, win 7, need some configuration in order to send the scanned documentComment
techhcet2000
How odd, teebee, Did you bother to read the manual yourself?
"Jan Sommer:
Section 8, page 85
Configuring the Network Interface
Board Using a Web Browser
A Start the Web browser.
B In the [Address] box, enter
the address (for example http://
XXX.XXX,XXX,XXX, where the Xs
are the numbers of the IP address).
The status of the machine you
chose appears on the Web browser.
C Click [Administrator Mode].
The dialog box for entering the
password and user name appears.
D Enter your user name and password,
and then click [OK].
To use the factory default account,
enter no user name and enter
“password” for the password.
E In the menu area, click the selected
item, and then make the necessary
settings.Last edited by teebee1234; 11-17-2010, 07:53 PM.Comment
