2027 scan to folder
  • kentong
    • 15
    2027 scan to folder
    hi,i got 2027 machine,but don't know how to install scan to folder,pls to help,thx
  • teebee1234
    • 1670
    You will need Scan Router Lite. Do a search of the forums for all of the discussions on it and where to download the software. You will probably be better off setting up Scan to Email instead.
    • Herrmann
      • Jan 2006
      • 792
      teebee, are you sure about the scan router? The 2027 should be able to scan directly without the scanrouter, but you are in need of the printer/scanner option and the memory upgrade
      If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
      • jonhiker
        • 661
        you are correct. the 2027 is the first model to support SMB folder scanning. you can also do scan to email. there is also a custom firmware update needed if scanning or printing via a share on server 2003.
        • XXX
          • 69
          I'd recommend replacing the Toshiba hard drive supplied by Ricoh before you go to the bother of setting up the address book.
          • teebee1234
            • 1670
            You're right herrmann, I must of been thinking of the 1027. Thanks for the clarification.
            • E Winter
              Are you talking about the hardware option or do you have problems software-wised? You can download all user manuals from ricoh's end user website in case you don't know how to register a scan-to-folder adress.
              It might be self-explaining if you handle it via the web-interface. I think the default admin log-on is no username and "password" as password. Once logged in you should be able to access and manage the adress book.
              • XXX
                • 69
                The logon user name on the 2022/2027 is password
                The Password is password
                Newer machines have a logon user name of admin
                Just hit enter or ok. A password isn't needed.
                • teebee1234
                  • 1670
                  Jan is correct, from the op manual.....
                  Attached is the Scanner Reference Manual that will help you set it up.
                  • XXX
                    • 69
                    To use the factory default account,
                    enter no user name and enter
                    “password” for the password.
                    How odd, teebee, Did you bother to read the manual yourself?
                    "Jan Sommer:
                    It might be self-explaining if you handle it via the web-interface. I think the default admin log-on is no username and "password" as password."
                    You won't find any reference to the web image monitor in the Aficio 2022/2027 users manuals and you won't find it in the service manual either.
                    • kentong
                      • 15
                      thanks all brother,i will try to do ,thanks
                      • smushrin01
                        l think the problem comes on the computer configuration, win xp, win 7, need some configuration in order to send the scanned document
                        • techhcet2000
                          Hello Everyone thanks
                          ok
                          • teebee1234
                            • 1670
                            "Jan Sommer:
                            XXX, are you even officially trained on Ricoh devices? If so, you must have been dozing during the training when they said reference the op guides because you obviously haven't read the manuals yourself. From the "Network Guide" op manual (which is available online to all users and techs who take the time to look)....
                            Section 8, page 85
                            Configuring the Network Interface
                            Board Using a Web Browse
                            r
                            A Start the Web browser.
                            B In the [Address] box, enter
                            the address (for example http://
                            XXX.XXX,XXX,XXX, where the Xs
                            are the numbers of the IP address).
                            The status of the machine you
                            chose appears on the Web browser.
                            C Click [Administrator Mode].
                            The dialog box for entering the
                            password and user name appears.
                            D Enter your user name and password,
                            and then click [OK].
                            E In the menu area, click the selected
                            item, and then make the necessary
                            settings.
                            • Llama God
                              • Mar 2009
                              • 1353
                              It's getting a bit feisty in here, isn't it?
