Display not working MPC2550
  • brodera
    • Aug 2009
    • 106
    Hi!
    I went on a MPC2550 this morning and the display dident work. Well it works but theres no text on the display just light form it. I change the Card under the display but no results.
    I also checked the Powersuply for brokend fuses but they are OK...
    Im out if ides. The machine is 2 weeks old.
    Quick answer is appreciated
  • teebee1234
    • Jul 2008
    • 1670
    When you say "Card", do you mean the LCD display or the touchscreen or both? If you have access to another MPC2550, swap out the entire control panel to test. If it works then swap individual boards out until you find the offending one. If another control panel has the same symptoms then you know you need to look at the controller/bicu.
    • brodera
      • Aug 2009
      • 106
      Yea i tryed to swap the whole thing but its the same. I also tryed to update firmware LCDC via Remote but that dident work either.
      I took the controler Card from the display and went back to my office and tryed it in another MPC2550 also same problem...
      Thx for quick answer.
      Sorry for my bad English.
      • brodera
        • Aug 2009
        • 106
        It was the LCD screen! changed it and its up and running now.
        Thx for the help Teebee
