Ricoh MPC3300 department codes setup
  • jonbonse
    • Jun 2009
    • 730
    Hi all
    I have read the manual regarding department codes but think it is quite confusing.
    Has anyone set this up for copying, printing and sscanning?
    If so I would appreciate your input.
    Thanks!
  • Jomama46
    • 2900
    copying, scanning faxing are easy. Set them up in the address book and define their permissions and grant them a user code. With printing you will also have to put the user code into the preferences tab of the print driver.
    sigpic
    A+; Network +; PDI+
    • jonbonse
      • Jun 2009
      • 730
      Thanks Jomama46
      The manual mentions to setup an Administrator password but cannot find where to do this. . .have you any idea?
      • Jomama46
        • 2900
        I dont think you have to but if you want to it is at UT SS Admin Tools> Administrator Authentication management. Or use WIM and go to configuration> then admin Authentication mgt.
        sigpic
        A+; Network +; PDI+
