SC:544 in Lanier LD015
  • rtg20
    • Aug 2025
    [Error Code] SC:544 in Lanier LD015
    Hi, our Lanier LD015 is generating this error code SC:544. The code appears as soon as you turn the machine on, even if it's been off all night. Any ideas? Thanks so much!
  • rsyarcia
    Hair Straightener Tech
    • 711
    check fusing unit for - Defective thermistor -
    Defective power supply unit
    Nobody is perfect..
    • rtg20
      Thanks for the reply. Do you know where I can get a service manual...?
      Thanks!
      • teebee1234
        • Jul 2008
        • 1670
        Thanks!
        Figures, someone actually asks for a manual and Paul isn't around!
        *check your PM box rtg20*
        • TonerMunkeh
          Professional Moron
          • 3865
          Thanks!
          Just call a tech. More than likely it will require a new hot roller or thermistor.
          Hit it.
          • rtg20
            Ok thanks to teebee1234's PM it's working again. :-) the fuser roller looks ok...smooth etc. (I think I was looking at the right thing!). Anyone know if it's possible for a non-tech like me to replace things like rollers and thermistors? this site sells them
            Lanier LD015 Supplies and Parts (All)
            Really appreciate all the help!
            • jonhiker
              • 661
              No it is not. This type of repair is best left to a qualified technician.
              • Llama God
                • Mar 2009
                • 1353
                It's a fuser error too, it needs to be reset via SP mode
                Although I agree with Jon, it's good that you got it sorted. Hopefully meltdown has not commenced...
                • rtg20
                  Ok if it happens again and won't go away i'll call for a tech. Thank you all again for your help!
                  • rtg20
                    Guess what?! The error came back. :-( It actually came back a few weeks ago...but not until today did we REALLY need the copier to work.
                    Anyway I need a tech in the south California area - Orange County. Any recommendations?
                    thanks!
