savin 4018
  • ValSupply
    • Feb 2010
    • 38
    savin 4018
    in resetting sc 542 on this machine i know have a problem where it says the right door is open. All actuators seem to be moving like they are suppose to, any suggestions on what might be happening. All help is appreciated. Thank you all and Happy Thanksgiving!!!
  • Jomama46
    • 2900
    If the door switch is OK, look for a blown fuse on the psu
    sigpic
    A+; Network +; PDI+
    • ValSupply
      • Feb 2010
      • 38
      all fuses are good, switches are ok. any other suggestions would be greatly appreciated.
      • randiman
        • Oct 2010
        • 27
        Check the center thermistor for build up clean and run
        Fusing temperature warm-up error (center): fusing lamp open
        Fusing temperature warm-up error (center): thermistor out of position Fusing temperature warm-up error (center): defective thermistor Fusing temperature warm-up error (center): defective power supply unit
        Dont know how the door switch figures in but Ricoh/Savin push switches are notorius for bein flakey.
        • ValSupply
          • Feb 2010
          • 38
          Thanks for suggestion so I
          Changed fuser out with "known to be good" and got same error.
          Any other suggestion much appreciated.
          • randiman
            • Oct 2010
            • 27
            That leaves the P/S
            • max28
              • 12
              Fusing temperature warm-up error (center)The fusing temperature rises less than7 degrees in 2 seconds, and thiscontinues 5 times consecutively.The fusing temperature is not detectedin 25 or 35 seconds.• Fusing thermistor defective or out ofposition• Fusing lamp open• Power supply board defective ( . ) Possible causes : )
              • olsong
                • 24
                Ok, I'll swap out the p/s tomorrow.
                Thanks a lot for all of your help. I'll let you know.
                • ValSupply
                  • Feb 2010
                  • 38
                  Swapped out the power supply board with "known to be good" same error.
                  So far we've eliminated fuses, switches, fusing unit and power supply board.
                  Any help much appreciated.
                  • randiman
                    • Oct 2010
                    • 27
                    Sc 542 is going to be limited to connections, devices (thermistors,thermostats).
                    Any paper in the connection? Obviously bent pins? Try the fuser harness - inside the m/c.
                    Does the fuser assy snug up to the m/c? I had the brass knurled threaded part in the frame keep twisting out when tightening down the fuser screw. Used some JB quick weld to repair it.
                    • ValSupply
                      • Feb 2010
                      • 38
                      Thanks for the advice, I'll check this out and let you know.
