Hi! First time poster, long time reader here...
Anyway, I have this problem with a refurbished Ricoh Aficio 2035. When I make copies on the machine using the rotate sort and double sided functions the third, fifth, 7th, etc etc bundle will have a black / dark grey background on the top and bottom edges of the page. Regular copies and normal sort works perfectly.
I already changed the transfer belt/ cleaning blade, which actually made the problem worse ie: the background became more pronounced. I also made sure that the transfer unit itself was perfectly clean and no residue was left on the rollers.
Since that didn't work I tried folling around with the transfer voltages in the service mode, which did made the background a bit lighter for a few copies, but I put them back to their default value.
Dev and drum have done around 40K copies so I assume they are still good.
Before I start changing high voltage boards / controllers is there anything else I should check?
Thanks!
ps: sorry for the bad English :x
Thanks!
