SC 396
  • hmac
    • Aug 2009
    • 129
    SC 396
    Hello,
    I have an MPC2050 with code SC396. I can not find the
    solution. The photocopier in one month only. Can you
    help me?
    Bye
    _________________
    HMac.
    _________________
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    396 relates to Bk drum/dev motor.
    Check if the drum is too hard to turn by hand. Compare with other units. There is also a torque check in sp mode somewhere.
    Check if the 24v fuse on the PSU has blown.
    Check drum/development motor.
    Also check for crimped wires.
    Have you done any work to this machine proir to this code?
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
