Gestetner DSc545/Richo MPC4500
  • Jr Garza
    • Apr 2025
    Hello, I'am in need of help on a sc548 code for a gestetner DSc545/Richo MPC 4500 dont have the sc code manuals so if someone with the code can guide me ,it will be appreciated.. thanks to all techs involved for helping to find solutions to different situations........
  • jeffreyozz
    • Mar 2007
    • 52
    sc 548- here ya go:
    Fusing unit rotation error. Fusing belt sensor does not detect change in the actuator for 5 seconds after the fusing/paper exit motor has turned on.
    Causes: Fusing unit incorrectly set. Replace the actuator. Replace the fusing belt. Replace the ih inverter. Check connections. Good luck.
    • tonyd
      sc548
      There is a firmware update for this code. basically you need to slide the fusing unit out, look into the machine where you pull it out and at the bottom left hand corner you should see a black sensor. it is common for it to pop out of place.
      • jeffreyozz
        • Mar 2007
        • 52
        We have this box in the field but it has proven to be a good running unit. So I will have to keep tabs on this one. Makes a tech look good when others have already had the problem.
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          Hey guy's there is an update for the sensor and the actuator, check the TSB's if you can. And I agree this is a vrey good box!
          Mystic Crystal Revelations
