MP2500
  • GeorgeBest
    • Jul 2009
    • 526
    MP2500
  • NeoMatrix
    Senior Tech.
    • 3513
    How many copies has the machine done ?
    1. Check the rego roller bush'(s) haven't collapsed.
    MPC or MP2500 ?
    2. The ITB (Image Transfer Belt ) not torn or damaged ?
    HTH
    GDM
    • Eric1968
      • 2458
      x2
      Almost 100% sure that the registration bushing(s) are broken. Often the one at the front.
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
        Paul@justmanuals.com
        • jonhiker
          • 661
          Originally posted by Eric1968
          x2
          X3. seen this happen may times. it breaks and the pressure is gone on that side, so the image is skewed.
          • PA5RR
            • Aug 2009
            • 62
            Most likely the front bushing is broken but it could also be the rear.... When you replace the bushing, secure the position of the regroller so it wil not be pushed out on the other side ! It 's a lot of xtra work when that happens.......Let someone fix the regrol into place while changing the bushing.
            technicians are the only ones that don't trust technical stuff !
