MPC2050 internal finisher paper stacking problem
  • Stevo123
    • Aug 2025
    The internal finisher does not consistantly stack papers correctly. Is there an adjustment procedure to adjust the jogger fences or has anybody come up with one?
    thanks in advance
  • zed255
    How'd ya manage that?
    • 1024
    The grey belts that pull the papers back into the finisher for stapling aren't making good contact with the paper. There is no 'adjustment' but a slight trim of the nylon holders where they contact the paper allows better belt contact. Only about 0.5 mm of material needs to be removed.
    http://www.copytechnet.com/forums/ri...correctly.html
