MPC2050 internal finisher paper stacking problem
  • Stevo123
    The internal finisher does not consistantly stack papers correctly. Is there an adjustment procedure to adjust the jogger fences or has anybody come up with one?
    thanks in advance
  • zed255
    How'd ya manage that?
    • 1024
    The grey belts that pull the papers back into the finisher for stapling aren't making good contact with the paper. There is no 'adjustment' but a slight trim of the nylon holders where they contact the paper allows better belt contact. Only about 0.5 mm of material needs to be removed.
    http://www.copytechnet.com/forums/ri...correctly.html
