Sc 471 ricoh 2238c
  • JOEBOOROCKSYOU
    • Jan 2008
    • 85
    Sc 471 ricoh 2238c
    ok guys , whats the most logical problem , we replaced the entire transport sec. with a good one that has a good belt , fixed it for about a week and now the code is back up..??
    were stuck , need some help...
    thanks,
    joeboo..
  • nmfaxman
    • 1702
    Check the transfer belt lift motor and gears in the back of the machine.
    The lower half lifts and drops.
    Pages 4-23 and 6-86/87 in service manual.
    • Ricohslave
      • 27
      The transfer belt lift sensor can get quite dirty with toner. There is a tab on the rear of the transfer unit that goes through the sensor.
      • bbapst
        • Dec 2008
        • 42
        check that the mylar on the right door isn't hitting mylar on the transfer unit. this can keep the unit from raising just enough it doesn't reach the sensor. you can trim the mylar on the transfer unit if its mangled.
