Print counter
  • hmac
    • Aug 2009
    • 129
    Print counter
    Hello,
    I have a MP3350, I would like to count impressions.
    I have a computer with multiple users, I would count the number of prints of each user.
    I is already counting the total number of impressions made from the computer. I put a user code on the printer driver.
    But how do you count per user or per session. I think installing the driver several times with different codes, but nothing prevents the user A of going to print to the printer of the user B.
    Help me please. Thank you
    _________________
    HMac.๏ฃฟ
    _________________
  • TonerMunkeh
    Professional Moron
    • 3865
    Can you not use one user code per user and get a user code print summary at the end of each day / week?
    Hit it.
    • hmac
      • Aug 2009
      • 129
      I hope that on one computer, I can count the impressions of many users. Without having to install several times the printer on the computer! Or install the same printer multiple times on the same computer, but how to prohibit a user A to print to the printer User B?
      Thank you in advance.
      I can count the impressions of a user on a computer, but I can not count the impressions of several users on the same computer.
      _________________
      HMac.๏ฃฟ
      _________________
      • teebee1234
        • Jul 2008
        • 1670
        You can install a custom pcl driver with a popup that requires a user code input with every instance of use. I've never done it myself but check the threads for the procedure or keep looking back here, someone with the knowledge will post something.
        Addendum- found this documentation on another thread (thanks go to Cipher), should point you in the right direction...
        YAPD Core Based PCL Driver Customization
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          The GUI based YAPD driver editor should be posted on the TRSC site any day now.
          It has cleared QA, and should be posted very shortly.
          No point in messing with all that XML jazz if you don't have to, right?
          BTW... This new version will also edit the Universal PCL6 driver. as well.
          โ€œI think you should treat good friends like a fine wine. Thatโ€™s why I keep mine locked up in the basement.โ€ - Tim Hawkins
          • XXX
            • 69
            I like questions like this because they get me thinking.
            If you use only one instance of the standard PCL 6 driver it's just a matter of the user remembering to delete the user code before the next person uses the computer. But what if you want to use the RPCS driver and have multiple printers called Bob, Ted & Alice that have user codes and custom print settings?
            I suppose that one way to control access would be to share each printer in windows and setup the permissions so only Ted would have access to his printer after he logs on to his account.
            This might be a better world without Windows, but it would be darker world if all I had for sunglasses were Apples.
            • victor25
              • 51
              If this YAPD thing works it will be sweet!!! I have a customer that wants to track print usage for there independant agents. Trying it out tomorrow, will post my results
              victor
              • tonnerboy
                • May 2011
                • 212
                I have several clients with this issue and I customize the driver. Whenever someone sends a print jumps a pop-up to put the code.
                Ricoh recently released an drivers editor that really comes in handy.
                Formerly it was needed to do it manually but now everything is easier.
                Go to the ricoh-suppport.com (i am from Europe. I dont know in America or other places).
                you will see that program (next the "up2me; Smart device, etc.). It is easy to work.
                • victor25
                  • 51
                  Re: Print counter
                  So I tried the driver editor and it works great on the newer machines, but it wont let me edit a 2510 or 3010 driver app So I edited a newer 3351 pcl6 driver and used it for the 2027 and 2510. Thought it worked great, so I walked out the door, but then got a call an hour later because the customer could not print PDF's. Now I am back to page 1, I need to figure out how to edit the original drivers... HELP... Does someone have an edited version already that I can get a copy of???? Thanks
                  • victor25
                    • 51
                    Re: Print counter
                    BTW.. I am only trying to pop up the user code dialog box. I looked at what gets changed by the editor, and it looked simple, so I added this same information/lines of code data to the 2510 driver. But no luck, the box doesn't pop up.
                    • victor25
                      • 51
                      Re: Print counter
                      GOT IT !!! The universal print driver is the key!!! I will now carry the universal driver and editor on my thumb drive
