When i first took this machine on about a year ago. I walked up to the machine to discover that the fuser did not turn. The reason was the Hot roller had a chunk about 1-1/2 inches wide missing(slightly off center) and bound up the belt so that it caused a sc520. I finally got this machine up and running with drums and most recently a dead sensor and a few other minor things(springs out of place,new exit unit) and now it has a sc 520(1 year later)
i walk up to the machine to fnid the exact same problem as when i first saw this thing a year ago. They do not print that much on it and the roller should not be worn out. I think it is a few years old and they have a total count of 350,000 copies on it(approx) The fuser was rebuilt in feb. i think.
I do recall seeing a service bulletin about a similar issue and it mentioned an sp adjustment to help prevent this type of thing. I am going to check into that but want to see if there is anything else i can do to prevent this from happeneing in the future. When i rebuild it everything was in great shape just the roller had a chunk missing so i replaced the roller the lower and the belt and the thermoswitch assembly. I am wondering if i need to put in a new belt oil roller or bearings or if anyone knows of any other issue that may be causing this to happen. Thank you
derrick
derrick
