Rico1515mf SC320
  • mrfuser
    • 1617
    Rico1515mf SC320
    Client says they took out a jam, then after they heard a "pop" and smelled electrical burn. Turned off and on and this code came up.
    Could a jam removal fry the Laser?
    Kelly
  • esd
    If they have knocked out or damaged the thermistor, then yes.
    • Eric1968
      • 2458
      Thermistor???
      • davidsautner
        Kelly
        No! Check the mirrow motor
        David
        • davidsautner
          it's the toner suppley tub fan motor front or rear.
          Replace the ventilation fan (at the left side of the machine)
          motor-front or rear.
          )David
          • jonhiker
            • 661
            SC320 isa polygon mirror motor code. If it won't reset, replace the mirror motor. it could be just coincidental timeing of jam and mirror motor going out. Although, i have never had one go "pop".
            • Eric1968
              • 2458
              From the service manual :
              Laser synchronization error
              The main scan synchronization
              detector does not detect the laser
              signal for 0.5
              Possible causes :
              Toner bottle not installed
              Loose connection between the LD
              unit and the BICU
              Defective cable between the BICU
              and LD unit
              LD unit out of position
              Defective LD unit
              Defective BICU
              Thermistors? Fan Motors?
              This is a Laser Unit Error!!
