First post ....
Problem with a LD032c or AF1232c....the consistantly jams right beneath the reg roller and sensor using both trays and also the bypass. Read the TSB about the black pad that is added to the opposite side of the sensor at the rear door. I didn't have the black pad, so just took a black sharpie and colored it black. This had no affect. Any other ideas?
Thanks!
Thanks!
