cl 7300
  • Latiff
    • Aug 2025
    [CQ] cl 7300
    I bought a second hand printer and the smc report inside the machine when shipped from factory is missing. Can any one please send me a copy of the smc report at least it will hell me in a starting point quicker.Especially the paper feed registeration and buckle correction
  • TonerMunkeh
    Professional Moron
    • 3865
    Although it'll be a bit more of a pain to sift through than the birth certificate, the SP mode tables in the service manual will give you the default values for all SP's. I'm not sure if another birth certificate from another one of these will give you what you're looking for, as they're unique to that machine. Correct me if I'm wrong anyone?
    Hit it.
    • techspec
      • Dec 2008
      • 128
      SMC Data is unique to each machine so data from another machine won't be any use to you.
      • E Winter
        There is no need to have the factory non-default page to adjust the paper feed registration. If you need those pages to get a better overview of the service settings you can print the SMC pages again - check SP5-990 (SMC Print).
        • Latiff
          Thanks will check that out
          • Latiff
            Yes you right that so true but it helps as a starting point when doing the adjustments,especially
            sp-1001,1002 1003 1004 1005 1006 1008 helps
            But the better way is to install the lates firmware i am busy sourcing one
            The trouble is i am an independant service tech and the Agents here in south Africa are not too helpful, I have now got a service manual if any one wants i can send via email
