ricoh 1075 ( really lanier ld075)
  • hockeyguy
    • Mar 2010
    • 6
    [Jamming] ricoh 1075 ( really lanier ld075)
    i have a ricoh 1075 jamming at the registration unit. b2 guide falls machine goes into jam.
    i replaced the registration motor,relay motor paper feed assy with the registration rollers.
    sheet bypass works.all paper trays jam. iam thinking the paper feed assy are bad. i took them out cleaned out dv. they were a noisey the noise kind of went away but still jamming.
    any ideas thanks.
  • ccchuah
    • Mar 2009
    • 153
    replaced all 4 pcs of one way bearing gear on the feed unit .
    • zed255
      How'd ya manage that?
      • 1024
      The mylar guides can wear through in the reg area causing jams.
      • hockeyguy
        • Mar 2010
        • 6
        hey thanks .replaced mylars and oneway bearing on paper feed units works great
        • zed255
          • 1024
          Nice to see the feedback regarding the solution.
          • TonerMunkeh
            Professional Moron
            • 3865
            It is a novelty, isn't it.
            Hit it.
            • TonerMunkeh
              Professional Moron
              • 3865
              Re: ricoh 1075 ( really lanier ld075)
              They're B065 2665 and 2675. Change them as a pair.
              Hit it.
              • hockeyguy
                • Mar 2010
                • 6
                Yes and you got make sure there is no dv in the gears
