Aficio 3260c Lubricant Bar
  • bat
    • Sep 2008
    • 138
    Hi all...
    The problem is that, Lubricant Bars (mostly magenta and black) are unevenly ''spent''. All PM parts are replaced at same time and so far have done 90k. Thanks...
  • Paranoid
    • 12
    If I remember correctly there is a weight bar that is placed on top of the lubricant bar andshould be pressing it down, from the looks of what you are having something is interfering with bar sitting correctly into the unit.
    • paulg
      • Jun 2007
      • 278
      I understood it to be with the heat was higher on one side
      • teebee1234
        • Jul 2008
        • 1670
        When was the last time the drum cleaning brush was replaced?
        • E Winter
          I have only one A5560 out there and I did just one PM so far (very low volume) - the wax bar looked kinda the same. My guess is that the housing/bearing is a bit notchy
          • bat
            • Sep 2008
            • 138
            All PM parts including brushes are replaced before 90k..
            • teebee1234
              • Jul 2008
              • 1670
              It may be the tabs on the end are bent out (or in for that matter) a little to far and causing the bar to hang up and not sit flush with equal pressure on both ends.
              • techsass
                • Dec 2010
                • 248
                I took the weights out of all my 3260s because the drums were getting coated with wax long before they were worn out. The problem comes back once the lube bar gets over 1/2 way down, so I just check & replace the lube bars now. Much cheaper than replacing the drum!
                • zaidi
                  • May 2014
                  • 6
                  Re: Aficio 3260c Lubricant Bar
                  [QUOTE=bat;191247]Hi all...
                  The problem is that, Lubricant Bars (mostly magenta and black) are unevenly ''spent''. All PM parts are replaced at same time and so far have done 90k. Thanks...[/QUOTE
                  this part happen to my drum unit? do i need to change it? is this the problem why my toner scatter into the transfer paper roller?
                    • 36796
                    This is a common occurrence on Ricoh color machines.
                    • Tonerbomb
                      AutoMajical Resolutionist
                      • Feb 2005
                      • 2589
                      Right on slimslob !!!!!!
                      Mystic Crystal Revelations
