Ricoh 2022 just waiting displayed
  • Rick
    • Mar 2007
    • 277
    This customer was copying 11X17 when the copier stopped with a copy half way through.
    The wrench came up then the customer turned the main switch off then on and the display now reads waiting and stays like that. I think its the hard drive but not sure . Anyone seen this before ?
  • zed255
    How'd ya manage that?
    • 1024
    Seen the 'Please Wait' before and it's usually the HDD, often if you wait long enough you get an SC also but the can take quite some time.
    • copyaction
      • Oct 2007
      • 991
      easy enough to check, disconnect hdd and see if it comes to ready.
      • jonhiker
        • 661
        if it does, reconnect the hard drive. if it will reboot, try reformatting the drive. if that works, be sure to due a major run of 11x17 to see if the problem re-occurs.
        • NeoMatrix
          Senior Tech.
          • 3513
          If the problem is what I think it is, then you may need to replace the main power supply.
          Sorry I have no other solution to give you....
          If you have a surplus machine you can borrow parts from then try swapping the main power boards.
          • Rick
            • Mar 2007
            • 277
            I do have a surplus machine and I will try the power supply I think you are correct . Thanks
            • Rick
              • Mar 2007
              • 277
              Nope its not the power supply
              • George J
                • 107
                +1 on the hard drive, we had to replace them on a number of machines because of this problem. As mentioned before you can try to disconnect the hdd first to verify.
                • Rick
                  • Mar 2007
                  • 277
                  I tried disconnecting the hdd and the same problem .
                  • b003ace
                    • Jun 2008
                    • 78
                    'Put it in service mode and scan the sc history to find out what that wrench was for. That should send you down the right path.
