I have worked on this copier about 3 times for misfeeds maybe more but 3 times where the problem appeared to be the same yet not. First time was due to leaking developer in pf assy. Second time paper catching in fuser. Third time paper stopping in duplex unit. Times 2 and 3 resulted in paper also stopping in same area as time 1 yet I believe it stopped there (right before reg. roler) because of paper stopping in Fuser time 2 or duplexer time 3. I'm wondering if this last time was due to enviorment. The copier has been in the same place all three times yet there were physical signs the first two as to reason for paper stopping. This third time and which I failed to mention I've been there a couple of times for this call and both times the copier had not been used till the big run was being made and the room was extremly cold. Flipping the paper each time allowed the copier to work.
Cold conditions affecting this???? Thanks!!!
