Ricoh 3713 service mode troubles
  • Maranatha
    I am also known as DHK, and asked yesterday for a way to get into the service mode on a Ricoh 3713.
    I received a kind response from "Fridgemagnet" that walked me through the sequence (as shown in my Intravia's). However, for some reason, as soon as I let go of the final "Clear/Stop" and hit "Print", it just goes out of service mode and gives me a copy. I even tried holding down "Clear/Stop" and hitting "Print", but with the same result.
    What am I doing wrong?
    I get the "dot" after pushing "71" and then "Clear/Stop" -- but after my next "Clear/Stop" the "dot" goes away. Never do see the blinking "5".
    Thanks again.
  • FRIDGEMAGNET
    • Aug 2007
    • 377
    Sorry about that Maranatha
    This the page from the manual.
    • Maranatha
      That confirms what is supposed to work, but what do you do if that sequence doesn't get you into the service mode -- like it should?
      • tonyd
        sp mode
        from what i remember with these machines you take the back off. on the main board u put dip switch 101-1 on and then off and then enter 97 and press the aps key. and then turn the machine off then on. but saying that i havent seen one of these machines for about 2 years
        tony
          • 23007
          It's been about 7 years for me...
          Turn ON dip SW101-2.
            • 23007
            Sw 101-2 gets you into service mode immediately. Simulation 97 is a reset for fuser codes. Since you have not specified what you're trying to do, a fuser reset may not be pertinent.
            • Maranatha
              That did it.
              Troubles resolved. Thanks a lot, guys.
