mp 6500
  • T911
    • Jun 2007
    • 628
    mp 6500
    Blank display. Are these lcd s natorious for going out. Sub power button is lit on the top right of operation panel but no response. Thanks t
  • Comatose
    • Jul 2010
    • 70
    Worked on many of these and not had one yet where the LCD has died.
    • T911
      • Jun 2007
      • 628
      So comatose u think it could be the control pcb for it then. Thanks t
      • jonhiker
        • 661
        when you power it on, doesit come to ready? do you hear any noises or do the finisher trays move? it could be some other issue besides a bad controol panel.
        • Comatose
          • Jul 2010
          • 70
          Before ordering parts I would take the panel apart and check for trapped wires, had a smaller machine work in the field for quite some time but then screen went dead and it was a wire trapped during manufacture, just took some time and vibration/panel being hit by stupid users for it to break.
          • TonerMunkeh
            Professional Moron
            • 3865
            That sounds more like a blown fuse, maybe a trapped wire in the fuser. Try starting it up with the fuser out and all options disconnected. If it starts, shove the fuser back in and connect the options one by one until it refuses.
            Hit it.
            • T911
              • Jun 2007
              • 628
              Went back today to see if I missed anything. Checked all fuses on lvps. Noticed the fuser wasn't warming and had the fuser out too i didn't see anything wacked out with the fuser or connector. When I first turn the machine on it powers and then seems like it doesn't want to boot up. I also had the display apart again but nothing. Too many variables right now. Thanks much t.
              • tcs04
                FORMER Techie
                • 1183
                Power down, open tray 1 (both sides), boot up... Ok? may be a short on the solenoid loom at the lower left front corner of the right hand section of tray 1.
                • T911
                  • Jun 2007
                  • 628
                  Tcs04 ill give the tandem a try thanks. Let you know.
                  • Lotec
                    • 97
                    I've had one (on a 2060) where a lamp connector was shorted to ground. The insulation had a cut, and the machine would not start up.
                    Very quickly to check, to rule that out.
                    • T911
                      • Jun 2007
                      • 628
                      Thanks for the help guys. Tcs04 was right on the money. Loom was ok but oct rear right cable was stretched sensors were all out rear flap broken and paper in the connector. Thanks spool much. T
                      • tcs04
                        FORMER Techie
                        • 1183
                        Glad to help + thanks for the feedback.
                        Train the customer to push the RHS of the tray in and load only on the left. This will help prevent future damage when they drop the paper into the right hand side and prevent jams due to misloaded paper as they can see the lead edge in the Left tray.
                        • ccchuah
                          • Mar 2009
                          • 157
                          Check the 5v and 24v on the power supply unit, if not replaced the power supply unit.
