MP2550 cassette 1 jamming
  • aabarnes1
    • Mar 2009
    • 620
    Swapped lift and feed units, new friction pads and rollers. Swapped trays and sensors.
    Machine still jams if you fill the tray. 100 sheets a4 or less and no problem. More than 100 sheets and the page wont even feed out of the cassette. Really strange fault, Jam is logged as tray 1 feed. Changed or swapped everything I can think of. Any help pls.
    Grant me the serenity to accept the things I cannot change.
  • jonhiker
    • 661
    Did you inspect what the parts catalogue calls the "rising unit"? it's part of the tray lift mechanism. what somtimes happens is the white plastic part that the that the shaft in the tray fits into gets cracked and will display the symptons you are experiencing. P/N D010 2780
    • Vioksrall
      • Sep 2010
      • 84
      I has to be adjusted through SP modes, please check the manual. It is explained how to adjust the lift timing either tray 1 or tray 2. Hope this helps.
      • bbapst
        • Dec 2008
        • 42
        check the paper size detector sensor behind the tray. remove back cover of machine, i've seen these sensors get knocked out of place. it adjusts tray lift depending on width of paper.
        • totoro
          • 568
          I have had to modify the spring in back that lifts the tray to have more tension. I have had to do this on some of the machines in this family like the 3030.
          Totoro
          • katash
            • May 2010
            • 221
            on the tray the guide that holds the paper if a little tight on the paper brings the problem realese so that there's space and test
            • rthonpm
              • Aug 2007
              • 2859
              See if unlpugging the paper size sensors on the frame of the machine behind the tray and manually entering the paper size and orientation in User Tools clears the problem up. I had a lot of these in dirty environments where the sensors would get knocked out of place or get so dirty that thy would read the wrong size, or no size.
              • moonraker
                • 28
                Try changing the cassette to A4R. If it feeds with a full tray of paper then it's the fault mentioned by bbapst in post #4 of this thread.
                • aabarnes1
                  • Mar 2009
                  • 620
                  Thanks for all the replies, I'll post back tomorrow with my findings.
                  • teebee1234
                    • 1670
                    I with jonhiker on this. I've seen it quite a few times and doing things like modifying the spring tension is just compensating for the split chuck. With more paper weight the split widens, preventing the lift plate from fully reaching its maximum height (though enough to actuate the paper present sensor).
                    • aabarnes1
                      • Mar 2009
                      • 620
                      Yeah, Johniker was right. That plastic chuck thing-cheers lads.
                      • flo
                        Engineer
                        • Mar 2009
                        • 44
                        Help for this
                        Sheet Paper Size Sensor
                        Partnumber D019-2796
                        its good to give it to all back sensors for trays
                        they nevercome up
