Ricoh Aficio 1515 Ghost image
  • iscott
    • Mar 2010
    • 344
  • rthonpm
    • Aug 2007
    • 2849
    Check the following:
    Paper and transfer roller: I've seen cheap paper and also damp paper in humid environments cause ghosting before. The transfer roller may also be shot, though this usually gives you laser looking spots.
    Pressure Roller: you said there's a new heat tube, but if the pressure roller isn't applying enough oomph it will cause issues. Depending on the number of clicks, also check the bushings for the press roller, they're plastic and tend to wear down over time.
    • jonezy999
      just one copy??
      • Feb 2010
      • 952
      X2 pressure roller bushings.
      I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
      • teebee1234
        • Jul 2008
        • 1670
        If the fuser isn't the problem, check the toner situation. Is it oem or generic?
        • jonw
          • 57
          agree with above sounds like crap toner
          • Eric1968
            • 2458
            If you open the side cover when the paper is at the drum position you can easily see if the ghosting is drum related or fuser related.
