Ricoh 1075
  • copyalbania
    • Aug 2009
    • 165
    Ricoh 1075
    Hello,
    I have a ricoh af 1075 and it shows error code sc-441.
    I have opened the drum unit and developer unit if there is a stuck there but nothing?
    Can anyone help please??
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    to following the solution you should be have her sm ...have you yet ?
    BEST TECHNICIAN . NICE PEOPLE .
    • copyalbania
      • Aug 2009
      • 165
      yes i have
      • zaza
        MECANOGRAPHE
        • Mar 2008
        • 1095
        then try to clean the tank unit developement
        • ccchuah
          • Mar 2009
          • 153
          Remove the developing tank unit and turn it manually to confirmed whether its jam or not.
          If yes, then look for the developer harden inside the dv tank that cause the jam.
          Or take out the development motor to check the wear off of the shaft and the bushing.
