LD335/345
  • RicohTech
    • Oct 2007
    • 30
    LD335/345
    Has anyone experienced problems with the developer severly dusting and clumping within 100K. The mag roller is coated dark and needs scubbing.
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Not on the newer models so far, but it's early days.
    The engine design and layout has not really changed that much for these 35/45ppm B&W models over the years.
    So it does not suprise me that they still suffer from the same old problems like coating of dev roller under the carrier.
    • RicohTech
      • Oct 2007
      • 30
      Mag Roller LD445c
      You would think they would have fixed the mag roller getting painted, the 35/45 series have been around for a long time.
      I forgot to mention that these are color mfds LD445c.
      • Cipher
        • May 2006
        • 1309
        Ah colour... yer the dev units can suffer from toner blasting and leak carrier under heavy use.
        But there PM yield for dev units is lower than 100k (60k or 80k something like that).
