Hi all, just installed a ricoh 1180L fax at a customer's site about 2 weeks ago, Jan 14th.
Customer called the other day and mentioned that they haven't received a single fax since it was installed, but told me the memory was full.
I ran through the op manual with her and I skimmed through the service manual to see if I could find a solution, but it wasn't very clear.
The fax reception mode is currently set to Fax out of Manual, Fax and Fax-answ.
Also set to WITH PAPER and not without.
So theoretically, all incoming faxes should be coming through and printed out immediately.
Anyone able to assist? Always appreciated.
