Fusing Problem
  • tcypy1961
    • 773
    Fusing Problem
    This Ricoh Aficio 350e was having fusing problems so I increased the temperature from 175 to 180, but when I checked the fusing temp. on the display, it said it was at 145. Eventually it did climb up to about 188 before I left but I was wondering if this is a problem with the fuser unit itself or is something else causing the problem? Any help appreciated, thank you.
  • Jomama46
    • 2900
    Could be a thermistor heading south. These machine often dont like 3rd party fuser rollers either.
    sigpic
    A+; Network +; PDI+
    • kenwood
      • May 2010
      • 2
      Check if the thermistor (s) are dirty or defect .
      Maybe the thermistor dot make good contact with the hotroller.
      Dont make the fuser temp to high because you get a thermostat problem or a sc code ..
      • Nortenio
        Did you check for parts updates to fuser frame/thermistors? Sometimes length/ angle of parts changes their performance and that will lead to SCs and other probs...
        • TonerMunkeh
          Professional Moron
          • 3865
          Christ with a machine this old I'd say the lamps were on their way out. It is 12 years old after all...
          Hit it.
          • ESA
            Clean or replace the thermistor. It's likely coated or maybe you have something catch between.
