2232c static shock!!!!
  • ash_572
    • Oct 2008
    • 523
    this machine has been working fine for 2years until today when nearly everyone in the office that went to pick their prints up from the machine recieved a very strong shock when they touched the machine. one customer said it was coming from the steel scanner frame underneath the scanner just where the internal tray is. i thought it might be a weak grounding to the scanner but when i checked, everything seemed fine. maybe i have missed something out. has anyone else had anything like this before??by the way, the customers are still alive.
  • Eric1968
    • 2458
    Could be a bad ground in the wall outlet. Maybe you should try a different outlet. Do they have new carpet that causes static charges?
    • Nortenio
      infotoons-october-2010.jpgCHEERS
      • rthonpm
        • Aug 2007
        • 2859
        Got to agree: it's a bad electrical ground. I had a 5635 in an office in a historical building: there was no ground in the electrical wiring so the machine would overcharge the developer and jam like crazy, as well as shock you whenever you touched the metal frame. Made service really fun: I used rubber gloves and a lot of developer!
        Refer the customer to their maintenance department or a qualified electrician if it's plugged directly into the wall outlet.
        • ash_572
          • Oct 2008
          • 523
          same old dirty carpet. my coleagues didnt seem to think it was going to be the machine.
            • 23009
            Too bad you couldn't boost the current a little ...
            I've got to agree with everyone. My memorable one was a Mita DC111 (no "C", it was the early b&w only version). They complained that they were shocked whenever they touched a cover screw. Sure enough there was a good strong tickle, 89VAC frame to neutral. And yes, they had yanked out the ground prong so they could use one of those nice 6A lamp extension cords. The extension cord was toasty hot too. =^..^=
