Erratic stapling @ Ricoh 2075 ST
  • Dexor
    • 223
    When I try to staple lets say 5 sheets, most of the time, but not always, it would staple only 3 or 4, and sheets first and last are usually not stapled. Sometimes it would staple just fine, but more often than not - I have this problem.
    I looked at jammed staples, lubed the plunger area, rails, bushings - no change.
    Any ideas?
  • TonerMunkeh
    Professional Moron
    • 3865
    Change the sponge tapping roller that sits above the stape tray, it gives the stacked paper in the jogger fences a tap to make sure they're all set straight. When they get worn, you get erratic stapling. Change the rubber belt at the same time too.
    Hit it.
    • Syscopiers
      • 9
      Check the springs on the idle rollers in section "R-4" of the finisher. Usually a spring comes off causing uneven pressure. This is usually the cause of the problem on the machines i've encountered.
      • Dexor
        • 223
        thanks guys for your input/solutions. It turned out to be worn-out belt on sponge roller, which also came loose. I know I will have to replace it, but it's working for now. I will also check the springs on the idle rollers in R4.
        Much appreciate!
