ricoh 1013f sc541
  • jeffreyozz
    • Mar 2007
    • 52
    ricoh 1013f sc541
    Ok- long scenario..... at customer office machine ran and ran and ran with paper getting to registration and no heat in the fuser. Brang it in, reset sp 5810 and got sc541 continuously(after rebuilding fuser, replacing heat fuse, and thermister) which continuity checks out. We have tried numerous ways of generating other codes, but as soon as we clear the codes, sc 541 comes up almost immediately, even with the fuser completely disconnected and the door open. Sounding like logic to us but just looking for the kiss method that will make me bang my head..
  • jeffreyozz
    • Mar 2007
    • 52
    just for an update- just because the part is new doesnt always mean its good. The thermister was bad.
    • Harry Buttar
      SC 541
      Please check fuser thermistor,fuser lamp ,fuse on power supply unit.
      Then to reset the error code you will need to enter 5-810 enter 1,then simultaneously press the original type key and the OK key.
