Ricoh 3501 only receives faxes
    Hi all
    Got a brand new straight out of the box Ricoh 3501 which works perfectly.
    I fitted a fax 5501 and it only receives faxes. When I send a fax it takes the document through the feeder and displays 'dialing' but I cannot hear any dial tone. In the logs it appears as waiting, after a few minutes the machine displays a transmission error or something like that.
    I have removed the fax and completely disassembled all boards and rebuilt making sure all connections are good.
    Is there a country setting I have to enter in service mode? the instructions don't say anything about this though.
  • Jomama46
    • 2900
    First make sure the line cord is in LINE not FAX. Then send a manual fax. Press OnHookDial, if you hear a dial tone, dial the number but dont press Start, just listen. If you hear another fax answer, press Start.
    sigpic
    A+; Network +; PDI+
    • E Winter
      Good suggestions - sometimes you may need to disable the dialtone detection (I think it's user switch 22 bit 0).
      • tcs04
        FORMER Techie
        • 1183
        Originally posted by skynet
        Hi all
        Not sure if it relates to this model, but there was a recent bulletin warning of fax unit mounting screws shorting against the fax pcb. Worth checking the length of the screws and insulating the edges of the pcb with tape?
        • Jomama46
          • 2900
          Good call tcs, this was that model. Symptoms are slightly different but worth checking.
          sigpic
          A+; Network +; PDI+
