Ricoh MP C3000 drums
  • jakabony
    Does anyone know if the color drums for a MP c3000 are interchangeable? They are a different part number, but they look identical. The black drum looks identical too and is $250 cheaper than the color drums. Has anyone tried to swap these?
  • unisys12
    • 489
    No, can't say as I have.
    Sorta off topic, but the toner is the same. The bottles are slightly different, 3535 & 4540 being slight larger. All my owner had to hear was that the toner was the same and next thing you know, he was only ordered the 3535 toner. Then a customer goes down, needing black toner for a 2525 and they send her a 3535 black. Customer calls back yelling that the bottle doesn't fit.
    Anyway, sorry about that. Just venting a little. We never discussed the differences in the drums in school, that I can remember anyway.
    sigpic
    The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
    • Cipher
      It's not easy being green
      • May 2006
      • 1309
      They use the same parts but I don't think they are interchange units.
      If I remember correctly the connector on the black drum unit is wired differently from the colour drum units.
      • Scott_Lewis
        • Mar 2007
        • 519
        I think if you look closely, you will find the drum units are
        keyed to each slot.
        • jeffreyozz
          • Mar 2007
          • 52
          I believe that they are to a point. I remember that the toner from the 3500/4500 will work on the 2500/3000. Even though each has its own part number.
          • Harry Buttar
            color drums
            Yes they are interchangeable but you have to file the connector at the rear end of the black to fit into color socket.
            • Anders Nilsson
              • 33
              I have swapped color and black PCU's in MP3000
              It works both way's also if you are out of Black PCU's you can modify the connector on a color PCU and if your'e out of color PCU's you can modify the connector on a black PCU
              • westpest
                You can use K for any colour, but because rear plug is very flimsy I spend an extra couple of mins and change the loom from old to new. Does not seem to alter CQ using K PCU's for all.
