MPC 6000 SC534 error
  • tibbs
    • Aug 2008
    • 225
    Hello, i have a Ricoh MPC 6000 with an SC534 error.It has something to do with the duplex fans but am not sure where these fans are located.Can anyone advise?
    Thanks much
  • Jomama46
    • 2900
    Look an the left hand side of the machine, they draw air out of the duplexer
    sigpic
    A+; Network +; PDI+
    • Wishbone
      • 100
      If you take the duplex unit out and look inside you will see 2 fans on the left and one in the middle of the frame. Due to the horrible design of the inverter unit customers can't get jams out without ripping the paper and it gets wedged in the fans causing the code.
      • tibbs
        • Aug 2008
        • 225
        MPC SC534 error
        Thanks guys, a rubberband got stuck in one of the fans.
