spc420 print quality
  • daveyball
    • May 2009
    • 314
    Hi
    I have SPC420 colour printer, with print qaulity issues, I have attached samples, the PCU's have been chagned. Any Ideas
    ThanksSPC420Samples.pdf
  • TonerMunkeh
    Professional Moron
    • 3865
    That looks laser or memory related to me. Have you tried reseating the memory DIMM's on the controller board and reformatting the HDD? Does the customer use the correct shutdown procedure at night or just drop the machine? I've had HDD's and controllers killed this way. Try a single colour test print on call four colours and see if any drift, that'd lead you to a laser issue.
    Hit it.
    • daveyball
      • May 2009
      • 314
      I agree with you on Laser, but I'll try the HDD, and memory stuff.
      • ricoco
        • Jan 2011
        • 122
        • daveyball
          • May 2009
          • 314
          SPC420Colour.pdfJust checked the machine has no memeory or HDD, I'm going to try the laser. I have attached colour examples this time, see how it's stretching the image, on the PCL config page
          • TonerMunkeh
            Professional Moron
            • 3865
            Just before you try a laser, if you can find the birth certificate check the laser SP's, see if any have changed. I'd be surprised if a laser has failed.
            Hit it.
            • SGT_Snacks-64
              • Oct 2007
              • 157
              Not sure if you re-calibrate the laser's like you do on this model like the MFD's, but might be something to try.
              Other than that I'd say Laser too
              ... lasers... pew
              Intel Core 2 Quad Q6600 2.4GHz (Oc'ed to 3GHz - Stock Volts)
              Asus P5E-VM HDMI
              4GB (2x 2GB) Corsair XMS Xpert II RAM
              ATi Radeon 4870 512MB GFX Card
              2x 74GB WD Raptor Sata HDD (RAID 0)
              500GB Seagate Barracuda Sata II HDD
              500GB Hitachi Sata II HDD
              600W500att OCZ PSU
              -TOTAL HDD SPACE 1148GB-
              • Gift
                • Mar 2011
                • 2458
                funny symptome - at least the edge erase does still work^^
                Besides checking the Dimm/HDD I'd recommend to perform an entire NV-Ram initialisation (backup data via sd card first) - maybe worth a try
                • daveyball
                  • May 2009
                  • 314
                  The actual samples have no edge erase, i think thats the Kyocera MFD I used to scan them, there is no extra memory or HDD in this box, and the laser looks a nightmare to remove. I'll try all then connections on the Main PWB, and HV PWB etc. and then maybe NVRAM
                  • SGT_Snacks-64
                    • Oct 2007
                    • 157
                    Yeah I believe (from an SPC420DN) you pretty much have to take EVERYTHING out of this machine before you get to the supple nectar of the Laser Unit (And be careful with the Ribbon Cable for the Laser Unit too!).
                    Try the simpler routes first before going for the biggie (i.e. HDD, RAM, NVRAM etc)
                    Asus P5E-VM HDMI
                    600W500att OCZ PSU
                    • daveyball
                      • May 2009
                      • 314
                      Will do, the machine has no contrract on it, so I will have to be careful with the man hours on this, a replacement machine will be more viable than if the laser needed changing
                      • SGT_Snacks-64
                        • Oct 2007
                        • 157
                        I'd probably agree with you on that one. You'll be looking at an hour easily for the Laser unit if you haven't done one before (It was the first call I had on one of these models), that's not including the cost of the part as well!
                        Asus P5E-VM HDMI
                        600W500att OCZ PSU
                        • Jomama46
                          • 2900
                          Looks like the line positioning is off, run 2111
                          sigpic
                          A+; Network +; PDI+
                          • Zeldaman
                            • Mar 2011
                            • 946
                            • Rain_City_Punk
                              Re: spc420 print quality
                              you may also try replacing the intermediate transfer belt and the Charge Roller unit as well as the Fusing unit for the device.
