Missing Magenta on MPC 4000
  • Kyokushin
    • Mar 2011
    • 7
    Hello
    i'm having a problem with a MPC 4000.Yesterday the maschine shows a SC397 Drum/Dev. motor error Magenta. i changed the drum motor and the development clutch.
    I restartet the maschine and it goes to Raedy, no SC shown. I tried to make the ACC, after the selfcheck the testpattern is printet but without magenta and no SC Code.I also changed with another Machine the PCU Unit no changes .
    Maybe one of u have a idea
    thx Kyokushin
  • ricoco
    • Jan 2011
    • 122
    Maybe the Transfer Unit. Have you saw that??
    • tcs04
      FORMER Techie
      • 1183
      Check the two white drive gears in the frame behind the pcu.
      • Kyokushin
        • Mar 2011
        • 7
        i checked the drum and dev. drive it works, the drum rotate in output test also the dev clutch. when i make a copy i dont have a image on the magenta drum only the other colors. i also checked the HV and the BICU
        thx Kyokushin
        • ss12
          • 289
          check the magenta transfer roller on the transfer unit
          • sharpmind
            • Sep 2009
            • 478
            change the development unit for magenta..
            • sharpmind
              • Sep 2009
              • 478
              i have encountered that problem and i found out that the TD sensor was failing..try to change the development unit and your problem is fixed.
              • Gift
                • Mar 2011
                • 2459
                I would stop the machine during printing a full page (e.g. A3 size) magenta pattern - then check the units to see how far the toner-image goes (or not). Maybe it's on the drum but not on the transfer film - maybe it's not even on the drum. You also might use a marker to paint a dot at the drum and dev gears to find out if they are turning during normal operation (not only sp test program).
                You can also try to interchange two color PCUs (maybe you have to swap the front caps and remove some plastic at the bottom side of the DV unit).
                • Kyokushin
                  • Mar 2011
                  • 7
                  i've also changed the pcu and dev. unit have still the problem. we chnaged the machine and take it back to our office to check inhouse, i will post the result if we found the error.
                  bye
                  • Ramón
                    • Mar 2011
                    • 26
                    Look this:
                    Shorted 24 V fuse on the PSU
                    • worksmart
                      • May 2010
                      • 16
                      I had faced the same problem with MPC 2550 - Magenta color missing (faded). Then after inspecting the usual procedure of toner quantity in the development and the Drum life, (everything was fine), finally I just removed the Image Transfer Belt Unit, cleaned the contacts and re-installed it. It worked!!!
