ola amigos, I have a problem aficio 650, he is burning the IC TD 62003ap, IOB board, I wonder what engine the portion of the machine may be short and this caused the burning of the integrated circuit.
ricoh aficio 650
Paul@justmanuals.com -
I dont think you will find that info in the P2P or service manual. Better to contact a board repair center and give them the IC number and see if they can advise you the component that is fed off of it. Aside from that it most probably is a pinched wire somewhere. Look in the area where the previous work was done.sigpic
A+; Network +; PDI+Comment
