Ricoh mpc 4500 sd card problem
  • georgereth
    • Jul 2009
    • 47
    After i have replace th controller board the machine goes to ready and works only as copier not as a scanner or printer
    the message is : Please call service and after that : sd card authentication has failed
    any ideas about that ?
  • rthonpm
    • Aug 2007
    • 2859
    Sounds like out of date firmware on the controller. Try updating and see if the message goes away.
    • jonhiker
      • 661
      After replacing the controller, make sure SP5895 is set to 1.
      But, you'll most likely need to replace the sd card.
      • georgereth
        • Jul 2009
        • 47
        If i copy the sd card from another machine with the sp5-873-001 move exec ?
        Is it possible that it works ?
        • tcs04
          FORMER Techie
          • 1183
          I agree, but maybe corrupt firmware. See if the machine will boot to an SD card with updated firmware.
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            5873 is for merging applications to 1 card. ie moving print scan to the postscript card or a java app., not for copying another application card. Typically you can get the print scan sd card from Ricoh parts for around $75.
            Mystic Crystal Revelations
            • Moza
              • 232
              Replace Memory dimm
