1027 adf problem
  • ponto700
    • 144
    1027 adf problem
    Hi,
    i recieve one 1027 with adf problem... the machine was working properly but since 2 days ago client cant make any copie from adf.
    i try to change all rollers, bels, peper separation roller, clean all sensors and still have the same problem. when i open the cover from the adf and i close the sensor when press copy the paper goes without any problem.. but if i close the cover the paper feeds.
    here the link of the video that i make with the problem.
    thanks!
  • TonerMunkeh
    Professional Moron
    • 3865
    That's a bit of a strange one, but it looks like a weak feed clutch. Try changing it and see what happens. Also, try running the DF in output mode and see if it does the same jam again.
    Hit it.
    • ponto700
      • 144
      TonerMunkeh,
      you right!! i run the df in output mode and nothing strange. after that i change the feed clutch and no more problems.
      thanks a lot!
