Lanier 6713 Copier synch problem
  • jcrayne
    I have an older Lanier 6713 copier that is copying out of synch. It seems that the paper actually starts through the track too early. The copy starts printing about 25% down the page. It seems that the timing of the paper transport is out of synch with the scanned image.
    I have checked all of the board connections that I can get too without too much digging. There are no error coded and no service wrench/indication.
    Please help.
  • Luther
    • May 2006
    • 682
    Re:Lanier 6713 Copier synch problem
    Old machine is right, either the registration clutch, or selonoid is dirty, i forget if it has a clutch or selonoid
    • 10871087
      • Jan 2005
      • 1062
      is the registration off a consistant amount (+/- 3mm) on every page out from all paper sources, off the glass or through the document feeder? if so you have an electrical issue or a tech induced error in the registration settings. If the registration varries or changes depending on the paper source then you have a bad clutch, solenoid, or sensor somewhere in the system.
      • jcrayne
        Thank you both for replying. The registration problem does not happen initially. It seems that if you leave the copier over night, the first copy will print correctly and then the 2 and 3 copies will be out of registration. Usually by the same amount. I am not sure about how consistently it is out though. It appears to be within the +/- 3 mm though.
        I will check these items and report back tonight.
        I have found very little in the way of a diagram for the machine. Look like it should be similar to the Toshiba 1350.
        Anywhere I can find an exploded view diagram of the copier?
        • jpcopy
          • Apr 2006
          • 256
          It is the reg,clutch . take off main board and mounting plate.
          will help you get it out easier. remove t/s unit .screws on front and back of reg roller assembly. will come out as a unit . replace or clean /light oil clutches. have had sucess with cleaning and oiling
          lol
          jp
          • jcrayne
            Thank you for your suggestions and help.
            I did take out the registration clutch(pic attached)
            here is a link to the part I removed and inspected:
            Premium genuine & compatible toner cartridges, fuser units, and maintenance kits for HP, Canon, Ricoh & more. Quality printer supplies with free shipping over $99. Trusted since 1974.
            The part did not appear dirty. I took it apart and cleaned it anyway. I did lightly oil the part and put it back together.
            Now when I make copies say 4 copies, The first and second copy looks correct, but sometimes the 2 and third are out of registration by about 3 inches.
            If I try to make one copy at a time, I may get a correct copy or I may not. Seems random.
            Again, when the registration is out, it is out by a good 3 inches. The paper transport starts way befor it should to match the image transfer. The result is 3 inches or so that is blank before the printing starts.
            If the clutch was not working at all, would the end of the print be blank or would I just get no print or mechanical error?
            Do you still think it can still be the registration clutch?
            There is another clutch mentioned, the \"CLUTCH - 6-R Clutch\" (pic attached)
            link to part: http://www.precisionroller.com/catal...&cid=24831
            I can not find where this part is to inspect it. Should I be concerned about this part?
            Thanks again for your help.
            • jcrayne
              Do you think it could be this registration sensor?
              [img size=420]http://www.copytechnet.com/components/com_simpleboard/uploaded/images/registration_sensor.jpg[/img]
              • jpcopy
                • Apr 2006
                • 256
                All reg problems we have had were repaired by r&r the clutch.
                Also you may want to check the dev mixer if you want this machine to perform properly even though it has nothing to do with the reg problem.
                lol
                jp
                • Jerry
                  Sounds like you are doing an excelent job. Change both registration and feed clutch at the same time. Will save you trouble down the road. This is very common on this box. Don\'t waste your time trying to clean, just replace. One other trick on this box. If it is jamming, check that all springs are under the lift place in the paper cassette, there should be \"3\".
                  Good luck
                  • dbrownlee
                    • Sep 2005
                    • 197
                    I definitely agree with Jerry and jpcopy. We keep a couple sets of the EM clutches in stock because we have so many in the field, and they fail so often. Replace both at the same time. The \"clutch 6r\" is located on the feed roller shaft. I have never needed to replace these in this box. Good luck.
                    Post edited by: dbrownlee, at: 2006/05/11 05:10
                    GO TIGERS!!
                    • jcrayne
                      Thank you for your help and response. The parts are on order and should be in early next week
                      • jcrayne
                        Since it is not an urgent situation, I decided just to replace the registration clutch only first. I finally received the registration clutch today and installed it.
                        The machine still has the same problem.
                        What should be the next step?
                        Thanks for your help.
                        • jcrayne
                          I am still in need of a little Help.
                          Should I go ahead and change the feed clutch as well. The copier seems to work well one time and then be out of sych the next. Again, the first part of the print is blank for about 3~4 inches when it is out of synch. Seems to pick up the paper early.
                          • jpcopy
                            • Apr 2006
                            • 256
                            sorry you are having such problems but the reg. clutch was always our fix. paper feed clutch would give you misfeed problems. recheck every thing could you have new clutch in bind?
                            lol
                            jp
                            • jcrayne
                              Thank you for your comments.
                              Are there any trouble shooting ideas to try?
                              I will double check the installation and the gears and mechanisms.
                              It troubles me that sometimes it does print normally(about 25~30% normal).
