Ricoh Aficio CL7200 color PCU
  • Bluezman
    • Mar 2009
    • 33
    [Error Code] Ricoh Aficio CL7200 color PCU
    Ricoh CL 7200 has Massage Replace color PCU Type A I have already replaced all the Image units still has massage and fails upon running Color registration
  • rthonpm
    • Aug 2007
    • 2859
    Could be that the little spring that tells the machine it's a new unit has broken. You can try manually resetting the PM counter for whichever drum doesn't show as replaced through service mode then rebooting the machine to get it to do pro-con. Also check the transfer belt, the rollers under it and the developer units for signs of wear.
    • Bluezman
      • Mar 2009
      • 33
      Service mode cl 7200
      How do you access service mode on this printer???
      • JustManuals
        • Jan 2006
        • 9838
        Just Manuals | The Internet's largest selection of manuals | Instant Downloads
        Paul@justmanuals.com
        • Paranoid
          • 12
          Entering the Service Program Mode - There are two ways to enter the Service Program Mode.
          Method 1: Turn the machine on while pressing the On Line key and Escape key together.
          Method 2: Press the Up/Down arrow keys together for about 5 seconds, then press the Enter key.
          7-804-xxx to reset the unit in question.
          1 - PCU [K]
          2 - PCU [Y]
          3 - PCU [M]
          4 - PCU [C]
          5 - Dev. [K]
          6 - Dev. [Y]
          7 - Dev. [M]
          8 - Dev. [C]
          9 - Oil Supply
          10 - PF By-pass
          11 - PF Tray 1
          12 - PF Tray 2
          13 - PF Tray 3
          14 - PF Tray 4
          15 - Fusing
          16 - Transfer
          17 - Trans Cln
          50 - All
          Hope that helps
          • oswaldo160
            • Oct 2008
            • 69
            Re: Ricoh Aficio CL7200 color PCU
            1 - PCU [K]
            2 - PCU [Y]
            3 - PCU [M]
            4 - PCU [C]
            5 - Dev. [K]
            6 - Dev. [Y]
            7 - Dev. [M]
            8 - Dev. [C]
            9 - Oil Supply
            10 - PF By-pass
            11 - PF Tray 1
            12 - PF Tray 2
            13 - PF Tray 3
            14 - PF Tray 4
            15 - Fusing
            16 - Transfer
            17 - Trans Cln
            50 - All
            Hope that helps
            Thanks, but How do you enter in The service program factor, because here you change the serial number. Help me.
